Originally Posted by boggtown
Thanks tool pants, I knew I had seen that pic before. So Id need a carrera oil pressure sensor (how much would that cost and how easy is it to change?), voltometer shouldnt be a problem, and Oil temp (How much for the sender and how hard would it be to put in?). If I can do the gauges for around 100 bucks I will.
The oil pressure sensor should be 996.606.203.01 assuming the info I got is correct, I haven't installed it yet. It's supposed to be a direct replacement that just has another terminal, you then run a wire to the cabin. I don't know about the oil temperature, please let me know if you confirm what is needed.
