Old 12-12-2006, 09:04 AM   #3
shift26
Send a message via AIM to shift26
Originally Posted by redducati750
Do you have the offsets for the wheels?
Sorry, I don't have them with me. I will try to post them later if I can get a hold of the manufacturer. As for fitment, this goes for either set... The fronts bolt up fine without the need of a spacer. The rears work fine with a 5mm or 7mm spacer. Those are needed to clear the brake calipers on the S model. I am not 100% sure if they are required on the non-S models, but I have 2 sets so I can provide one pair with either set of wheels. The 19x10.5's with the spacers fill the wheel wells nicely. My Boxster was lowered about 1.5". I did not have any rubbing issues on any of the 4 corners... not under hard cornering, heavy braking, sharp u-turns, or entering/exiting driveways. I hope this info helps.
Atilla
shift26 is offline   Reply With Quote
