Old 12-09-2006, 05:26 PM   #7
Brucelee
Brucelee's Avatar
Smile
Originally Posted by z12358
Rich, thx. I'll figure something out. My main question was whether large temperature changes (deep cold) outside (though covered, like a porch) would hurt the battery in some way. In winter, it's hard to find an area that's BOTH ventilated AND temp controlled (heated). The answer, I assume, is that the cold isn't going to hurt the battery.
Z.
If you have a tender on the battery, the cold is no issue, UNLESS it is SO cold that the fluid will freeze. I DON'T know what temp that is but you can find that on the web I bet.
If you are not putting a tender on it, then yes, the battery will die faster in an unheated space.
BTW- the auto stores keep batteries inside the store by the dozens. I don't think that ventilation issue is all that critical but I bet Minn Jim would know.
Good luck.
Rich Belloff
