Old 07-11-2004, 12:37 PM   #6
geoffe
I just had my iPod installed into my Boxster S. Though I have a Kenwood deck that allows for AUX input instead of the factory deck with AUX input, the process is the same:
1. I went to the Porsche and purchased a dash odments tray to replace the CD storage unit in my dash. I cut a slot in back (near the middle) of the tray for my iPod cable to use. (In my case, I actually replaced the "DSP" panel at the very bottom with an odments tray).
2. I purchased the "Belkin Auto Charger w/Audio for iPod" (available at Apple.com/iPod or the Apple store). This plugs into the power socket in the car and provides an adjustable line-out from the iPod. A single cable runs from this to the dock connector on the bottom of the iPod.
3. I went to Magnolia Hi Fi, a decent car audio shop, and had them remove the CD storage unit, connect the AUX connector to the deck, and hard-wire the Belkin adapter to the car. The cable from the adapter to the iPod was set in the slot I'd previous cut in the odments tray.
4. We connected everything up to the iPod, tested that playback worked, and used the volume knob on the Belkin adapter to adjust the level so it matched the radio/cd player.
5. Finally, we tucked the adapter behind the odments tray, set the odments tray in place, and voila.
The final result is simply a white iPod cable with a dock connector tucked into a odments tray -- if you've seen the BMW commercial, it looks exactly like the connector in the BMW glovebox.
I can take pictures of the final install if people are interested.
- Geoff
geoffe is offline   Reply With Quote
