Old 12-08-2006, 09:32 AM   #3
BobMarley1
re
The noise is caused by brake pad vibrations.
Go to your local auto store and look for some brake pad (stuff), I forget what it's called. Look in the brake section. It's basically some goop you put on the side of the brake pad(the metal part), and on the shims too, if your car uses them.
It will dry to this semi-stiff layer of plastic type stuff.
Hope this helps, also, take a stiff stream of water to your brakes, it might just be some dirt lodged somewhere.
BobMarley1 is offline   Reply With Quote
