Originally Posted by jci-joe
Quote "Where are you getting your information on tire life?"
I have the Bridgestone Potenza SO3's and I am told they are summer tires and should be driven with caution below freezing. Right now they have about 16k miles on the current set of tires and the back tires are very worn. I stepped on it pretty good the other day and the back end really shot around. The temp at the time was about 40F. I think that was more due to poor tread than temperature, however, I think below 32F they may get worse.
I am now researching new tires and like most topics here, there are enough opinions.
Old tires need to be replaced even if they aren't worn. The industry sources that I've found say 7-10 years is the max life of a tire. Mnboxster states a shorter time span without stating his source.
