Old 12-05-2006, 09:50 AM   #1
SD987
As of 6/06, these were the TSBs out on a 05 987 base. Since then, as others have noted, there's something out there for the windstop clips. My 06 has the new clips and still rattles, so don't get too excited about that.
W566 - Adding convertible top emergency tool to the vehicle tool kit
W573 - Service Action - retrofitting studs for the engine carrier with caps
W574 - Installing washers on exhaust system bracket clamps
If you haven't switched tires yet, the rears at the least will be due ($), and it wouldn't surprise me if they tell you that the front brakes will be due sometime soonish.
You may also want to take this time to modify your OBC settings for any of the following, assuming you don't have PCM.
Daytime running lights (did it on the base, will do again on the S)
Auto-locking doors above 5mph (did it on the base, but annoying to me after awhile)
Side-markers blink with turn signals (plan on doing next time on the S, didn't know about it when I serviced the base)
I get condensation streaks when I've washed the car the day before, or when the car is parked outside overnight, which isn't often.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
