Old 12-05-2006, 09:08 AM   #28
bmussatti
Guest
Posts: n/a
Originally Posted by Adam
They usually take your used engine, as mentioned earlier. 10-15k is way high for even a slightly used boxster engine. They probably sell it on the aftermarket like you want to. You may get 3-5 k for a slightly used 2.7L or 3.2L engine. There was a nice 3.6L 996 engine with less than 5 thousand miles on it on ebay a few months back for 5.5k. I'd be happy with a 3.6L boxster with 320 or so hp. Any car with a power to weight ratio of 10hp to 1lb or greater is pretty fast.
Hi Adam:
I think you mean 10 pounds per 1 HP.
In actuality, I think it would be closer to 9 pounds/1 HP assuming the car weights about 2,900 pounds!!
