Old 12-03-2006, 04:18 PM   #1
wvicary
First all congrads on the car and second, to repair the wiper just pop off the little black cap where the wiper arm meets the shaft... you'll then see a nut- I thinks it's 13mm in size- and snug it up.
Be carefull not to over tighten it as people have damaged or broken the shaft in the past and take the time to rest the wiper blade/arm in it's correct position on the window before tightening.
As for the relays, they can a bugger to pull out of the relay box.... carefully wiggle the relay slightly back and forth while pulling. Thats always worked in the past for me. I've also heard that the horns are of very poor quality so you might have more then one problem.
wvicary is offline   Reply With Quote
