					Originally Posted by blinkwatt
				I was considering the LItronics but then I saw how much work & drilling was needed to add Litronics.  A shop quoted me at $300 to install them.
They're plug and play if you don't care about the swivel up feature when you put on the high beams.  The low beam xenons work fine just popping in the headlight without doing anything else.
With the wiring installed, the litronics swivel up when you put on the high beams to help the high beam lights illuminate even more on the road, but I found that without the swivel up, there's still plenty of light, so I didn't bother.  The other function the wiring provides (level sensing) doesn't work unless factory installed because there are sensors that go to the wheel axle to determine initial leveling.
You can still sell your halogens on fleabay for up to $600 and get Litronics for $900 (one set just sold for $910 IIRC).
