Remove the top relay/control unit and see if there is a black dot on the base. There was a bad batch of 2000 relays but I would have thought they would have all failed long ago. Give it a tap and put it back in. Then find another 2000/4 Boxster and swap relays to rule out the relay. The relay from a 1997-1999 is different.
