Old 07-01-2026, 09:42 PM   #6
997_986
What I’d at least check now would be the spark plugs, the coils (including their connectors!), the MAF and the fuel injectors. The latter can be deactivated individually via Durametric, allowing you to compare the results with the others.
A vacuum leak is, of course, the obvious suspect, you mentioned that you chased down all of them, but have you carried out a smoke test?
997_986 is offline   Reply With Quote
