Old 05-21-2026, 03:28 PM   #19
BrakeExpert
The fluid type and viscosity isn't going to affect your "shifting" immediately, its far more likely there's a problem elsewhere, like it was overfilled, a vent is plugged, a shift cable got stuck, but replacing fluid will not cause a hard shift from an immediate drain and fill. Also, yes 75w-90 fluid does stink, all the time, that part is normal. Gearbox and differential oils smell bad, usually the thicker they are the worse they smell, don't know why.
BrakeExpert is offline   Reply With Quote
