Yes, that part is hard to explain. You mention also the shifter was changed at some point in time.
Maybe it is good to understand when you started noticing the hard gear engagement. Was it only the difference before / after fluid change? Or any other things done in between?
The shifter might be it, but also a worn clutch (or clutch hydraulics etc) could give similar issues.
