Old 05-04-2026, 02:07 AM   #6
tcoradeschi
Registered Member
Originally Posted by Dllrd23 View Post
Fairly unknown. Bought it from a guy who was converting a Boxster to electric. Prior to install, I replaced most of the external things like thermostat, water pump, AOS, AOS pipes. I bore scoped, pulled the pan, and replaced the IMS bearing. The only thing that raised a red flag was some sludge in the pan but it did not go higher than a couple of inches in the sump. My hunch is that the oil rings are stuck and that is only because I don’t believe that stem seals could leak that fast to create the amount of smoke that is being produced. My next idea is to kill each cyl 1 at a time by disconnecting coil and injector to see if any 1 cyl smokes more.
That’s a good plan.
I am concerned (as I suspect you are) about your comment about the amount of oils sludge in the sump. Are you literally saying it was a layer a couple of inches deep? The AOS pickups are down there, I think.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
