Old 11-22-2006, 07:55 AM   #16
clb0099
Window motor/Regulator
So the only way to see what is dead would be to take it apart. Does anyone know if there is any other way to test if the motor is still good. Thank you for the answer about the window relay. Also how do i get the window down to access the bolts on the clamps holding the glass. Is there some kind of trick. I have read the window project but do not see anything about if your window is stuck in the up position.
clb0099 is offline   Reply With Quote
