Old 04-08-2026, 11:21 PM   #9
997_986
The first thing is to read the codes with PIWIS/Durametric or another suitable code reader. These engines are not prone to failing lifter(s). When you already had a oil pressure issue it is most likely that you still have a problem with that, changing the oil of course helped but this is "the small scale on the balance". You have the possibility to check oil pressure very simpel. I would start with that!
997_986 is offline   Reply With Quote
