Old 03-27-2026, 06:54 AM   #2
JFP in PA
Originally Posted by MrBoxster986 View Post
I have a 2001 S with 54k under its belt. Pampered car that’s never missed a service. Randomly, it failures to start. The starter motor spins with great vigour buts there’s no spark. I’ve replaced plugs, all coils, crank sensor and fuel filter. My local specialist has now said it might be that modern fuel is the problem and I should try reddex!
Has anyone else had this issue?
We have seen this when the crank position sensor is going south; the immobilizer in these cars is programmed to shut off the fuel and ignition if the immobilizer does not see the engine turning over, which it gets as a signal from the CPS. This could be a harness problem between the sensor and the immobilizer, causing the intermittent issue.
