Old 03-07-2026, 10:35 AM   #2
KevinH1990
KevinH1990's Avatar
I installed a URO ignition switch that failed after about a month. I replaced it with another URO switch and that one has been fine for several years. I have seen several threads that suggest URO's quality control may not be at the same level as some other brands.
Given the symptoms you described and my experience, I think it's possible that you installed a defective part.
Good luck.
KevinH1990 is offline   Reply With Quote
