Old 03-01-2026, 05:25 AM   #2
austinporsche
Never Mind . . .
Before removing the door panel again and diving back into the microswitches and latch actuator, I needed to drive the car somewhere, so on that drive, I went thru the window "learning" sequence again and again (maybe 5 times) but holding it longer than 5 seconds (maybe 15-30 sec). When I got to where I was going, I tested both the inner and outer handle drop function -- and it all worked as it should.
Go figure.
austinporsche is offline   Reply With Quote
