Originally Posted by Gilles
Try applying 12VDC to the cigarrette lighter plug, this should allow you to open the frunk.
Note: Don't use a battery charger as a power source, because it will not work, it is best to use the battery from another car with the jump cables connected to the lighter adapter.
Good luck!
I really would not be trying to connect a high amperage source (battery) to the cig lighter, the wires in the dash are too thin to carry the load. Use the pull out in the fuse panel and use a suitable ground connection.
