Old 02-23-2026, 09:26 AM   #7
Uwe
Bluetooth harness
I installed a bluetooth harness a while back, and so far it has proven to be a good solution. I do not remember the brand, but I did buy it from Becker. It came with OE style connectors, all wiring, and a small microphone for hands free calling. The module fit behind the dash, mine is to the left of the radio. The sound quality is satisfactory, almost comparable to playing CD's. My 2000S has the 6-channel stereo package with DSP, but I dont believe it matters as far as installation is concerned. One must select the "aux" input function, and that's it. Mine automatically connects every time I turn the key when my phone is near by. It plays streamed music, as well as downloaded music on my phone, and reads directions through the car speakers when I use my maps program. The hands free function works well, interrupting the music for incoming calls. In my case, I have to slow way down or pull over for calls, due to the noise level at highway speeds. No fault of the system, but rather the inherent noise of my car. I drilled one of the blank switches to the left of the control bezel, and fed the microphone through the switch, secured with a dab of silicone. A small wind cover made of foam then slides right over the microphone. The convenience, sound quality, and reliability of this modification makes me think that it is a good solution for those that want to keep the car somewhat original.
Btw, some Etsy sellers have laser printed adapter rings for the OE Porsche dash speaker grilles, requiring only to remove the factory speaker, only requiring changing of the push connectors for the speakers. I forget the size of the speaker at the moment but they are readily available for less than 100.00 for a decent pair with the tweeter built into the center ( coax). I first had Pioneer product, but did not like the sound at all, changed to Rockford Fosgate. Better. but still not great. At some point I will upgrade all the speakers, but as of now it is pleasant enough to accept it as is. My musical genre is Jazz centric.
Uwe is offline   Reply With Quote
