Old 02-14-2026, 12:31 PM   #4
elgyqc
elgyqc's Avatar
Nice and easy project! When you replace the slip ring and resolder the terminals to the ends of the coil, make sure you use a small amount of soldering iron but try to build it up to last. The pulley is about 3-times smaller in diameter relative to the one on the crankshaft, meaning it can spin well over 10.000 rpm, on average! I had to redo the soldering on mine when it snapped after a few thousand miles during acceleration .
Not too difficult it is true. The alternator is back together now and I have been trying to test it (there are several Youtube videos on how to do that) but I am getting no voltage to the attached battery. I suspect the the drill that I am using to rotate the rotor does not turn fast enough. I calculate that the alternator turns about 2.5 times the speed of the crankshaft so at an idle of 700 rpm the alternator should turn at 1720 rpm. My drill gives about 1200 rpm. So I am trying to think of a way to get it to turn faster with what I have available.
Because the pulley I took off the alternator was seized I decided to verify the pulley on the alternator that is installed in my base Boxster that I am selling... and found it was seized also, so I bought a new pulley and installed it in the car. When my Boxster S comes out of winter storage I will check its pulley also. It seems that that is something worth doing when the front cover is off the engine.
Grant
