Old 02-11-2026, 06:24 PM   #1
Sandy G
Shifter Improvement Suggestions Wanted
I have a nice 2000 Boxster S with 45,000 miles and everything works great! The main thing I want to improve is the shifting. It works fine, but there are a couple of issues I’d like to address:
  1. When the engine is cold, the first shift into 2nd gear is a little balky. No grinding, just kinda stiff going from 1st into 2nd. After it warms up, it shifts ok into any gear. My solution is to start the engine and then row thru the gears before I drive away, and then my first shifts while driving feel better.
  2. Overall, the shifting feels “thick,” both when cold and fully warmed up. There’s a fair amount of slop in the shifter, too. One time I drove another 986, probably with an aftermarket shifter, that felt great – nice and snappy and tight – so I know mine could be a lot better.
Here are the options that come to mind:
  • Use an alignment tool to adjust the shift cables. Cheap, just time consuming.
  • Clean and regrease the shifter while I’m in there. What lubricant should I use?
  • Replace the shifter with a new one of the same type, or a short shifter, or from a different model Porsche.
  • Replace the cables. Living in a condo, I’m pretty limited on work I can do without taking it into the shop, so this would be a little pricey.
  • Drain and replace the transaxle fluid. This would also need to be done in the shop.
Any thoughts? I prefer to keep it close to stock and I don’t want to spend a whole lot on a minor issue. Thanks in advance for any comments or suggestions!
2000 Boxster S MT 45k miles
Sandy G is online now   Reply With Quote
