Old 01-31-2026, 02:38 PM   #3
spinjockey
I think that’s the vent line for the fuel tank. It connects to the filler neck. You’ll need to get a new line because those hardline hoses are molded to the connectors. If you cut or heat it, the new connector won’t fit tight and you’ll get a check engine light for gaving an evaporator system leak.
spinjockey is offline   Reply With Quote
