Old 01-03-2026, 03:55 PM   #3
Jerry1847
I'm 100% with you there. Do you, or anyone, know a way to diagnose? The code was not present prior to the cat failure. Common sense tells me it's likely timing, but I don't know how to confirm, or how to test an electrical issue. Is it as simple as putting a multimeter on the connectors? Are there any relays that could have failed? I don't know much about the cam timing.
Jerry1847 is offline   Reply With Quote
