Old 11-19-2025, 07:25 AM   #5
blue62
If there is a permanent twist in the clamshell
the arms that raise it or the mounting points to the body.
You will probably never adjust the twist out.
I would take everything apart and make sure there is no twist present in any of the parts.
Once your sure there are no twists in anything then you have a good baseline to start with.
blue62 is offline   Reply With Quote
