Old 11-17-2025, 02:47 PM   #8
Smallblock454
As the rear brakes seem to be fine, i would suspect the brake booster is OK. Because front left and rear right and right front and left rear are connected. I suspect the front brake cylinders in the calipers to be bad.
Also, how old is the brake fluid and what type was used? DOT4 and DOT5 should be changed every two years. DOT5 is not allowed not be mixed with DOT4.
Smallblock454 is online now   Reply With Quote
