Old 11-09-2025, 02:20 PM   #6
Pringle86
Yes, the clutch and brakes share the same fluid reservoir in the front trunk near the windshield. Check the fluid level and top it off with DOT 4 brake fluid if it’s low. If the clutch still sticks, the slave or master cylinder may be failing and could need replacement or bleeding.
Pringle86 is offline   Reply With Quote
