Old 11-09-2025, 08:50 AM   #11
Marc_986
I ordered one of the plastic covers for the brake reservoir of a RHD car. It was cheap, so shipping costs a bit of time, but I might get it later this week.
Old brake line is removed, new one is waiting for me at the dealer. Gave me some time to look at the parts on the wreck. I can't use that subframe is it has the additional bolts to the chassis. Was looking at that because one threaded hole in my subframe is damaged from removal of the bolt. Well, I think it was already damaged by the looks of the stuff that came out. Looks like it was glued in place. Anyway, it shouldn't be too hard to repair the threads, or rather drill it out and tap it one size bigger.
The front ARB was removed from the wreck and this is the 24mm one. So I need to think which one to place on my car. Leaning towards the thicker one, accepting the increased understeer for the time, until I swap the rear one out. This does feel a bit better to me as I still need to get to know the car.
Also I looked at the wiring diagram of both cars. As far as I can see F7 (in the power distribution box) should not be present in my car. So I can either use this for the additional fuse required by the ABS, or I can use it for the power steering pump. My first thought is that it is most tidy to use it for the power steering and tap the additional ABS power from one of the unused fuses in the fusebox.
Marc_986 is offline   Reply With Quote
