Thread: Litronic repair
Old 11-04-2025, 11:40 AM   #1
alexc0814
Litronic repair
Hi, I just picked up a pair of litronics. The driver side light was pointing too far down, so I tried to adjust it. The adjustment was doing nothing at all, though. So I popped open the housing, and both the motor adjustment with the black ball and socket joint and the other white ball and socket joint are mostly broken. I can get it locked into position, and when it is, the vertical adjustment works, but I think after hitting a couple bumps it will probably just fall right out of the joints again.
Has anyone completed a repair like this? I don't need the motor function since its retrofitted into a halogen car, so I'm considering something even like superglue at worst since I got this set quite cheap and the passenger side appears to be good.
alexc0814 is offline   Reply With Quote
