Old 11-02-2025, 03:17 PM   #1
jluetjen
Registered Member
I'm afraid there's not much room for adjustment in this case. If you realign everything, that is going to affect primarily your exhaust camshaft and that's independent on the variocam. The variocam units adjust the intake camshafts only and there is no adjustment there. So, unless your long chains are badly stretched out or your chain has skipped a tooth already, you will find that the alignment is fine. But that does not mean the post variocam alignment is good, and that can't be adjusted.
Good points. Not much of a benefit.
I just got the tools in last night. I'm ready to get started.
jluetjen is offline   Reply With Quote
