Old 11-02-2025, 06:30 AM   #1
PaulMc
Removing Stuck Up Spoiler
Hi Folks,
I had issues with my instrument panel where it would fault and cause all the warning lights to come on and the spoiler to raise, I swapped the cluster, and it is now behaving. However, the spoiler has been stuck in the up position for several months now. The rocker does not work other than I can hear the relays clicking. I suspect the motor or maybe microswitches although I can't make a case for the motor since it was fine, but could for microswitches maybe. Either way, I am trying to remove to inspect and since the rams are up, can't get the assembly out. Any tips? I am trying to remove the motor, but it's virtually impossible to get to it since the assembly doesn't move much due to the rams being extended. If anyone has any ideas on pieces to remove or experience with getting this out with the rams up, it would be great to hear.
Cheers,
Paul.
PaulMc is offline   Reply With Quote
