Old 11-02-2025, 04:13 AM   #2
jluetjen
Registered Member
After a night's reflection -- grinding down the sleeve would be a mistake since the knurled adjuster is retained by a slight swage at the too of the skeeve. But a few washers that fit around the sleeve and under the nut will do the trick.
I suspect that the tooling which swages the sleeve has warn over time (worn down, and now it doesn't press as far down on the sleeve as it used to.
jluetjen is offline   Reply With Quote
