Old 10-27-2025, 02:44 PM   #1
Hilly_2xo
Originally Posted by Danimal View Post
Try adjusting the shifter so it moves forward a bit mores and see if that helps. I installed one of the BAD shifters and had the same issue, took some fiddling to get it to clear going into reverse.
Thanks Danimal, I can’t adjust where the actual housing sits, but I have tried adjusting the cable seating - the grooved sheath the ridged barrel pin sits in. Even in its lowest setting is still rubs!
Seems like the cable isn’t long enough.
Hilly_2xo is offline   Reply With Quote
