Try adjusting the shifter so it moves forward a bit mores and see if that helps. I installed one of the BAD shifters and had the same issue, took some fiddling to get it to clear going into reverse.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
