Thread: Losing Coolant
Old 10-25-2025, 11:09 AM   #2
alexc0814
Did you remove the trunk carpet? I had the same symptoms, but lost less coolant than you. Either way my carpet itself was never wet, but when I pulled the carpet and the hard foam underneath it up there was a pool of coolant. There's also a little drain plug type thing that will release that coolant when it starts sloshing around (when you drive).
Your previous owner may have replaced with a non OE unit, which are known to fail quicker.
alexc0814 is online now   Reply With Quote
