Flywheel Balanced & installed, but...
I finally received my balanced DMF & pressure plated from Flat 6 and installed it yesterday. Throughout this project, I've learned as I've gone, so to speak and yesterday was no different. I used new Porsche flywheel bolts, torqued them to 19 ftlbs and then began to torque them to 120 degrees. I used a Harbor Freight digital wrench for the first time and my inexperience resulted in some inconsistent readings. Should I be concerned if the the flywheel bolt's torque, range from, say, 112- 121 degrees with one possible as low as 100?
