Old 10-14-2025, 11:45 AM   #5
Gilles
Motive Power Bleeder
Sam, you mentioned that you are not a mechanic, but bleeding the brakes (and clutch), is not a difficult task, as long as you can put the car on jackstands to remove the four wheels.
I would suggest you to buy a Motive Power Bleeder, is not expensive and very easy to use, there are many videos showing the bleeding process, good luck!
