Old 10-01-2025, 08:18 AM   #15
wywyatt
Well, got some values with the car warmed up and at temperature right before it cuts out. Here are some interesting ones;
Camshaft deviation bank 1 is -7.83
Camshaft deviation bank 2 is -8.75
So they were right at the shop before! I was hoping they weren't...
I took a good look at voltages after JFP in PA brought that up;
Supply voltage drops down from 13.6 to 12.5 as the engine warms up. These are both measurement's at idle. A/C and headlights are off.
When the engine finally did cut out, I had only the supply voltage log open and it cut off at 11.25v when the engine stopped, and was like that for a second before.
Going to research alternator/voltage regulator failure as well as call a mechanic and get a quote on replacing those camshaft timing chain wear pads.
I had 3-4 misfires but I assume that's from the camshaft being so out of spec.
Also wondering how out of spec the aftermarket fuel regulator is. It's got a screw thing on the top and isn't like any of the ones I've seen for this engine. I'm replacing it with a stock P one from pelican, just have to wait on shipping.
These mean anything? Bad ECU/DME? Just double checking, I can read that they say nothing is wrong :P
wywyatt is offline   Reply With Quote
