Old 09-13-2025, 12:40 PM   #4
Gilles
Originally Posted by PA Boxster View Post
Thanks, yeah I figured that would probably be my next step in trying to fix the issue. Is a squeaky master cylinder a common problem with old clutch (brake) fluid?
Honestly, I am not sure, but since you mention that the noises started after the repair shop flushed the brakes and Not the clutch, it could be an indication, at least after you flush the slave you will know that all the hydraulic system has fresh fluid..
