Old 09-12-2025, 02:16 AM   #7
tcoradeschi
Registered Member
So, in general, not bad news, as I read it.
You clearly have vacuum leaks to clean up. Getting the injectors out, IIRC, is a bear of a job, so I would revisit that thought later. How did the determination that it is running very rich come about?
Your belief that checking the camshaft deviations should be done with the engine at temperature is correct. Discuss that with the shop to see exactly what they did. Typically that is caused by worn actuator pads - replacing those is DIY-able, but is around 4.5 wrenches out of 5 on the difficulty scale.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
