Old 09-08-2025, 06:45 AM   #13
JFP in PA
Originally Posted by Petecomplete View Post
Will loosening the front engine mount only, and lower the engine 3-4cm with a jack work for him in this case? I did this when i changed my engine mount and its not and absurd amount of work.
Not really; undoing the front mount and lowering the engine will actually raise the trans slightly, which is the opposite of what you need to do. Undo all three mounts while supporting the engine/ trans, then lower it just enough to get at the problem as you don't want to be over stressing hoses and wire harnesses.
