Old 09-08-2025, 01:06 AM   #12
Petecomplete
That looks to be in the tip's coolant valve area; if so, you are going to need to lower the engine and trans a bit to gain access.
Will loosening the front engine mount only, and lower the engine 3-4cm with a jack work for him in this case? I did this when i changed my engine mount and its not and absurd amount of work.
Petecomplete is offline   Reply With Quote
