Old 09-02-2025, 11:36 AM   #4
BoxsterInTheSun
Like I stated I am making very very broad guesses as I don't have any further info on your car.
One thing to try is disconnect the MAF sensor and go for a drive ...... see if there is any difference.
When you disconnect the MAF sensor.... the DME will revert to a default fueling MAP.
02 sensors that are starting to "age out" can be tricky to diagnose that is why I stated you need the proper test equipment and test knowledge.
Bosch: (They were the first to adapt the 02 sensor to automotive use)
States that an 02 sensors life is 100000 one hundred thousand miles.
So they are aging out or slowing down at that point.
I did actually try this at the time. There was no difference with the MAF sensor disconnected at all, so maybe I can rule that out?
My 2002 base model has 138000 miles on it, so not out of the realm of possibility that the O2 sensors are aging out at this point...
BoxsterInTheSun is offline   Reply With Quote
