Old 09-01-2025, 10:28 AM   #2
JFP in PA
First of all, Porsche coolant is a concentrate, and you really do not need 20 litres, particualrly if you are leaking; total wast of money.
You can buy a coolant UV dye from Amazon, Uview and other make it, for a few bucks. Dump a dose into your coolant tank, adjust the level with distilled water, run the car for a few days, then put it up in the air and us a UV light to pinpoint where it is leaking from. Once you find, and fix the problem, you can plan on dumping the system and doing a coolant system maintence.
Don't look for a bandaid, fix the leak.
