Old 08-25-2025, 12:31 PM   #10
Lacostas
Originally Posted by Danimal View Post
I am having issues with my locks randomly not working. I checked the immobilizer and there is no corrosion. And changed the passenger door lock actuator, no change.
The locks will usually work in the morning or the first 30ish minutes of driving. Then when the car gets warm or after it’s over or under charged they no longer work. My charging system also reads 14 something at the battery and 13 something per the dme. So I’m wondering if I also have a voltage issue somewhere. Possibly to my immobilizer. My car also chugs a bit with the ac on at idle.
Please keep us posted on what you find.
As a first step its good to replace both DME relays (in trunk) and see if it helps. Cost me like 7 EUR each. Then maybe try to measure the voltage on those relays and check where the drop happens and if voltage reaches them intact or lower.
Lacostas is offline   Reply With Quote
