Old 08-25-2025, 09:01 AM   #8
Danimal
I am having issues with my locks randomly not working. I checked the immobilizer and there is no corrosion. And changed the passenger door lock actuator, no change.
The locks will usually work in the morning or the first 30ish minutes of driving. Then when the car gets warm or after it’s over or under charged they no longer work. My charging system also reads 14 something at the battery and 13 something per the dme. So I’m wondering if I also have a voltage issue somewhere. Possibly to my immobilizer. My car also chugs a bit with the ac on at idle.
Please keep us posted on what you find.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
