Old 08-24-2025, 05:04 AM   #5
tcoradeschi
Registered Member
Originally Posted by Lacostas View Post
Hey All,
So ive been trying to identify why my DME "Supply Voltage" reads around 13ish Volts but the voltage on battery is around 14.3, on my 2004 986 2.7 M96.23
some symptoms:
- Random ABS/PSM Light on
- Huge struggle whenever radiators, AC are on
- Random idle struggles
- Remote key not working (new remote - dealer programmed it but no luck)
Ive already replaced both DME relays but no luck. Next step i guess is the DME Ground point but other than this im out of ideas.
Thanks as always
Are you measuring the actual voltage or reading it with Durametric or some other device?
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
