Thread: Ims separation
Old 08-23-2025, 07:13 AM   #2
JFP in PA
Did you lock the engine at TDC and employ cam holding tools before starting work on the chains and guides? If not, the engine has jumped time due to the pressure exerted on the cams by the valve springs, causing the IMS shaft to move upwards and usually to the right.
